Exporting to Stand Alone
Posted: Thu Feb 25, 2016 6:01 pm
Can anyone give me some guidance on the best way - if possible - to export a scene with materials form the DAZ Octane plugin to -> Stand alone Octane?
Community Forums for OTOY Customers
https://render.otoy.com/forum/
OcDS System Tab:bpzen wrote:Can anyone give me some guidance on the best way - if possible - to export a scene with materials form the DAZ Octane plugin to -> Stand alone Octane?
compare:IMPORTANT: You need to have started rendering with OctaneRender prior to using these export functions, otherwise the Mesh nodes will be blank when you open the exported scene in Octane Standalone.
compare:From release 3.0.4.11, when you save to an Alembic file, the plugin will also save to an OCS file which contains that ABC file, with all the material connections in place. The OCS file saved to be the ABC filename with a .OCS file extension.
1) It can render vertex motion blur. 2) You can add Volume nodes to render VDB files.- What is the benefit of export to Standalone? What's better?
I'm not sure. I know you can export from DAZStudio and import into OctaneRender for Nuke. But unsure of the Houdini import functionality.- Can I use Octane Render Export (DAZ Studio) and import in OctaneRender Import (Houidini)?
The features that are available in OctaneRender standalone but (not yet) supported in OcDS may change over time.Veneris wrote:- What is the benefit of export to Standalone? What's better?
