Embedded nodes visibility
Posted: Mon Feb 22, 2016 12:19 pm
by Stassius
On the obj level i can switch node visibility to make object renderable or not. This is logical.
But when i have an embedded multilevel obj-nodes (for example, RIG or fbx import) - Octane doesn't use visibility flag on the top level node. You have to go inside and manually switch nodes on-off, which is inconvenient in case of multiple nodes (such as fbx import).
To recreate this problem you can Create subnet from any node in the obj context.
Re: Embedded nodes visibility
Posted: Mon Feb 22, 2016 10:44 pm
by juanjgon
Thanks for reporting. I will try to fix this problem for the next build.
Posted: Wed Feb 24, 2016 7:49 pm
by Stassius
And another one. I noticed that bypass flag doesn't work in shader context. For example i use some Tool node after Texture and want to compare before-after.
Switching bypass flag doesn't work. I have to rewire network.
Posted: Thu Feb 25, 2016 11:13 am
by juanjgon
Stassius wrote:On the obj level i can switch node visibility to make object renderable or not. This is logical.
This problem has been fixed in the next build.
