Displacemant accuracy
Posted: Mon Feb 15, 2016 10:02 pm
Hello!
I just wanted to work with some displacement settings. The displacement has go inside,
so I inverted the map, set the Height to 0,005 and, to keep the rest of the surface on the correct level, I tried to put
the Offset to -0.005. But no result. The Offset only takes whole numbers, no decimals... and -1 is way too much.
Is this an issue of the plugin or does this belong to the Octane Render Engine?
Thanks for help...
Eddy
Thanks for help...
Eddy
