Plugin 2.25 (not new problem) reset/fix asp do nothing
Posted: Fri Feb 12, 2016 10:12 am
Hi!
I have noticed this problem with earlier versions so it is not new in 2.25 but it is still there so now I need to ask if there is something wrong with my setup or is this a bug
When I open IPR, the window aspect is the default, not related to camera aspect. By the manual I understand that IPR window should reset the aspect to match the current Camera if I activate Fix Asp and press Reset. But no matter what I do, nothing happens with neither Reset nor Fix Asp (Fix Asp button toggles but it has no effect on anything)
When I later load the scene again, the IPR aspect may have changed to match the current Camera but then again if I change Camera aspect, those buttons in IPR do nothing
Is this bug or have I misunderstood something or is my LW/Octane setup messed somehow?
Thank you!
Antti
Thank you!
Antti
