Can not delete Nodes in the node editor
Posted: Tue Feb 09, 2016 3:42 pm
by johnhill
I can not seem to delete any nodes in my node editor...it must be a simple thing to do?
Re: Can not delete Nodes in the node editor
Posted: Wed Feb 10, 2016 8:33 am
by bepeg4d
what happen if you right click on a selected node?
Don't you see the "Delete" command?
Anyway, if you select a node and press DEL in your keyboard, the node should be deleted, isn't it?
ciao beppe
Posted: Fri Feb 12, 2016 5:21 pm
by johnhill
I've tried both those options..I wonder if there's a bug in my C4D version?
I also get a DLL errors when I load Cinema 4D...not sure if this is also a bug or not.
Posted: Fri Feb 12, 2016 9:04 pm
by aoktar
johnhill wrote:I've tried both those options..I wonder if there's a bug in my C4D version?
Is It C4D plugin? Which version? Did you removed unnecessary plugin files as in readme.txt?
Posted: Fri Mar 04, 2016 7:58 am
by corneliuz
I feel with you ;-) I have the same problem. I can´t delete nodes in the node editor.
No right click, no delete button works. I checked already for unredundant plugin,
but there is only the R16-octane-plugin in the plugins-folder.
My workaround is to delete the node in the c4d material editor, but this isn´t really
a solution.
This happens with c4d R16 and Octane latest version and also the version before.
Posted: Tue Apr 05, 2016 9:50 am
by johnhill
this is very strange - I can not delete a node using the backspace/delete keyboard button - I have no menu when I right click the mouse either. Once the node is in the node editor its there for good...really annoying.
There must be an obvious fix..I have a couple of plugins when I load C4D that aren't working..maybe they effect the Octane plugin in some way? I'm using Cinema 4D R17 and Octane 2.5 R3 plugin and latest OS X
Posted: Mon Sep 12, 2016 7:02 pm
by Gertsch
Hi Guys,
I have got the same issues on R17 + octane 3.0 demo.
Right click is not working and I can't delete nodes.
Does anyone have a solution?
