Displacement Map not working with ColorCorrect Node
Posted: Fri Dec 18, 2015 5:21 pm
by 3dreamstudios
Is there a reason running a texture/diffuse node through the color correct node will mess up the displacement node?
1. If I run a texture node directly into the displacement node the displacement works.
2. If I run the texture node through a color correct node so I can adjust the image on the fly, then run that adjustment through to the displacement node the displacement does not work.
Bug, doing something wrong...or don't understand? Thanks.
Re: Displacement Map not working with ColorCorrect Node
Posted: Fri Dec 18, 2015 5:38 pm
by juanjgon
Displacement currently doesn't support the color correction node (or any other procedural or tool node). Only the texture image node can be linked to the displacement texture input.
Posted: Fri Dec 18, 2015 5:41 pm
by 3dreamstudios
juanjgon wrote:Displacement currently doesn't support the color correction node (or any other procedural or tool node). Only the texture image node can be linked to the displacement texture input.
Is this a limitation of the code or just hasn't been developed? It would be a great addition if we could modify on the fly the characteristics of the image to be used for Displacement. I'm not finding an easy way to get the look I want without a bunch of back and forth with Photoshop...
Maybe 3.0?
Posted: Fri Dec 18, 2015 5:47 pm
by juanjgon
The problem is that if you build a render tree with color correction nodes and so on, the render of the displacement can be a lot slower, so it has been limited to use only the texture node by design.
Posted: Fri Dec 18, 2015 8:04 pm
by FrankPooleFloating
Hmmm... It is a little strange that we can mix LW procedurals at will and plug into Octane displacement, but not color correct...
Posted: Sat Dec 19, 2015 12:41 am
by juanjgon
FrankPooleFloating wrote:Hmmm... It is a little strange that we can mix LW procedurals at will and plug into Octane displacement, but not color correct...
You can mix LW procedurals because all this node tree is backed as a single texture map before pass it to Octane. You could color correct a LW texture using this workflow, but you can't color correct a texture at render time using Octane nodes, because compute this node tree for each texture sample is really slow for the critical displacement code.
https://docs.otoy.com/Lightwave3D/?page_id=564
Posted: Sat Dec 19, 2015 12:48 am
Yeah, that is what I was thinking, that one could just use LW nodes to cc... a workaround...
