displacement problems.
Posted: Mon Dec 14, 2015 10:15 pm
by scratch33
I have some issues trying to displace a snowy landscape.
I can't mix 2 textures with texture mixer to displace a map. If I try this, displacement simply don't work.
Is this a limitation?
Thank you
Re: displacement problems.
Posted: Mon Dec 14, 2015 10:45 pm
by FrankPooleFloating
Doesn't material mix node have a displacement input?... Don't have LW near me at the moment, but I think it does. Plus UVs are required for displacement. You have a UV?
Posted: Mon Dec 14, 2015 11:58 pm
by scratch33
Yes material mix Has displacement. But if you try to combine to 2 dispalcement it dosen't work.
Yes I have an uv map
Posted: Tue Dec 15, 2015 1:00 am
Could you not do something like this?
Posted: Tue Dec 15, 2015 9:35 am
by juanjgon
The Octane texture mixer node can't be used for displacement, but as FrankPooleFloating says, you could mix the maps using the LightWave texture mixer before plug the final texture in the Octane texture node.
Posted: Tue Dec 15, 2015 4:53 pm
by vipvip
Good to know, thanks
Posted: Tue Dec 15, 2015 10:26 pm
by scratch33
Cool thanks. Good results.
Thanks for the tips.
