				Octane Render for SketchUp 2.23.2
				Posted: Thu Dec 10, 2015 11:24 pm
				by CaptainCrowbar
				I've made a new build of the SketchUp plugin. This is a minor update; the main change is that we now officially support SketchUp Pro 2016. The installer will add the plugin to SU 2016 by default, but you can still use it with SketchUp Pro 2015 simply by selecting the appropriate directory when you run the installer.
We've also changed the plugin version numbering scheme so plugin versions will match the corresponding Octane version.
Octane Render for SketchUp x64
Octane Render for SketchUp x64 (Demo)
EDIT - I've taken the links down, there's a problem with the installer. Will fix as soon as I can.
				Re: Octane Render for SketchUp 2.23.2
				Posted: Fri Dec 11, 2015 2:12 am
				by rfox
				whenever I try to install the plugin, it always says
setup blocked - there is another install of this package is already running
 ....see attachment
and when i click "close" button it says Successfully installed. but octane button won't show up inside sketchup menu.
any clue to solve this problem?
				Posted: Fri Dec 11, 2015 9:27 am
				by pasmangiu
				yes i have the best solution , just forget the sketchup plugin , try octane for max , or any other 3d aplication , they all work great , and they all have all the fatures
you can build your 3d models inside sketchup , and than just import in 3ds max and render with octane for 3ds max
				Posted: Fri Dec 11, 2015 1:16 pm
				by pasmangiu
				atleast fix the proxy isue before realising the 2016 version
				Posted: Sat Dec 12, 2015 10:58 am
				by Interfaces
				Thank you for this update.
it will be necessary to add the node graph (the same thing as in standalone)
add export option in the standalone version as TIG.
personally I use the plugin only for proxy I exports to standalone.sinon Version I always use the plugin TIG much more convenient. a color is equal to a material!.
When auons us an update with the node graph and when we realize pourons video with octane.
THANKS
				Posted: Sat Dec 12, 2015 10:59 am
				by smicha
				Interfaces wrote:Thank you for this update.
THANKS
+1 These are exactly my thought and requests for years!
				Posted: Sat Dec 12, 2015 2:04 pm
				by pasmangiu
				what update ?
i see no download link
				Posted: Mon Dec 14, 2015 6:46 am
				by skibbbi
				Where is the link to download?
