opacity silhouette edge object shape
Posted: Wed Dec 02, 2015 9:35 am
by Andygraph3D
is it possible make trasparent only the silhouette edge of a object ?
Re: opacity silhouette edge object shape
Posted: Thu Dec 03, 2015 1:25 am
by face_off
Unsure what you are trying to achieve here.....what object exhibits this light behavior?
Posted: Thu Dec 03, 2015 10:39 am
by gordonrobb
Not sure if you'r trying to make the edges transparent, or everything but the edges transparent. Im sure a fall-off node plugged into the opacity could do something for you though.
Posted: Thu Dec 10, 2015 2:26 pm
by Andygraph3D
yes this node do it on edge object, but not on silhouette alone .. i want create a blured edge on a object silhouette
Posted: Sat Dec 12, 2015 1:12 pm
by TRRazor
Didn't you ask the same question about 2 months ago?
Would you maybe have a picture of what you're trying to achieve?
viewtopic.php?f=45&t=50947
Posted: Wed Dec 16, 2015 4:50 pm
by Andygraph3D
This is an example of what I mean, think these three objects as if they were a single object.
Posted: Wed Dec 16, 2015 8:27 pm
by face_off
This needs to be done in post processing - using Nuke or Fusion. Render out the beauty pass and blur in Nuke/Fusion with the Opacity pass (in Octane 3).
Posted: Thu Dec 17, 2015 9:53 am
by Andygraph3D
With AE can do it without using octane 3 .. I wanted to know if with octane 2.x had to achieve the effect without postprocessing.
If i use falloff node are able to do something similar but unfortunately I apply transparency also at the center of the object ..
