Team Render "Missing plugin Octane"
Posted: Sat Nov 28, 2015 10:17 pm
by jingles
I'm having issues team-rendering a basic scene that is NOT using Octane in any way. No tags exist on objects/cameras/lights and i've even removed all render settings except for the most current which is Physical Renderer.
I can't post the scene publicly but can share directly if pinged.
Any idea what's up?
THanks
Re: Team Render "Missing plugin Octane"
Posted: Sat Nov 28, 2015 10:33 pm
by aoktar
Do you see any error messages in Console window? I'm testing a simple scene with physical render+TR. Client has not Octane and renders fine.
Posted: Sat Nov 28, 2015 10:44 pm
by jingles
Only noticed error messages on the client console which read the standard "missing plugin *plugin name* (ID xxxxxx)" .... attached.
I've had these two machines render successfully this week. The scene many versions ago had rendered with octane.
Thanks for the quick reply.
Posted: Sat Nov 28, 2015 10:48 pm
by aoktar
Are you sure that Octane is not in list of VPost part? If so can you share with me a simple scene to check that?
Posted: Sat Nov 28, 2015 10:49 pm
by jingles
Here's a grab of the render settings. Is that what you mean by VPost?
Posted: Sat Nov 28, 2015 11:09 pm
by aoktar
Do you see second render settings? It has OctaneRender as renderer.
Posted: Sat Nov 28, 2015 11:11 pm
by jingles
What did you press to reveal that / 2nd render settings? As you can see from my render settings grab I only have EXR Preset listed.
Posted: Sat Nov 28, 2015 11:19 pm
by aoktar
jingles wrote:What did you press to reveal that / 2nd render settings? As you can see from my render settings grab I only have EXR Preset listed.
This is your scene you sent me. Apparently it leaves some footprint after OctaneRender assigned. This causes error on client which has not Octane.
Workaround: Copy/paste all of your objects to a clean scene. And render it by TR.
Posted: Sat Nov 28, 2015 11:40 pm
by jingles
So odd! baffles me.
thanks.
BTW I'm using R17 and think its most recent version. Octane version 2.24.
