Displacement artifacts
Posted: Wed Nov 25, 2015 11:21 pm
by mdharrington
I am getting straight line artifacts in my displacements....which I assume are from polygon edges in the displaced geometry, seeing as they don't move with the displacement texture, but they do move with the geometry
It looks as if the displacement does not go across polygon lines perfectly.
In testing however, subpatching the object removes the artifact....so not sure if this is UV related
these lines also appear in the alpha channel
Re: Displacement artifacts
Posted: Thu Nov 26, 2015 1:49 am
by mikefrisk
Is smoothing on? Turn it on if not.
Do you have a bump or normal map applied as well? Try disabling them.
Posted: Thu Nov 26, 2015 2:53 am
by mdharrington
smoothing did the trick .....as well as subpatching
thanks
