Wish: visibility options indepenent from live update ...
Posted: Mon Nov 16, 2015 5:17 pm
by Micha
Hi Paul,
could you change the options so that live update isn't needed to be enabled for all the other options like visibility? For example I have a scene where I like to change the visibility of some objects, but I don't need a live update of this objects.
An other problem is - for a quick scene setup of a non-complex scene I like to enable the live update for all objects. I selected all objects and enabled the live update, but the live update was enabled for one object only.
Ciao,
Micha
Re: Wish: visibility options indepenent from live update ...
Posted: Mon Nov 16, 2015 9:44 pm
by face_off
This is not possible - sorry. When a Rhino mesh is NOT live, then it will be stored in a whole-scene Octane mesh node (with all other not-live geometry). So a scene refresh is required whenever you change the Live status of a Rhino mesh.
I was not able to reproduce this problem. You can load all Rhino mesh objects "live" by setting Live Updating to "All Meshes Live" in the Settings.
Posted: Tue Nov 17, 2015 7:33 am
by Micha
face_off wrote:could you change the options so that live update isn't needed to be enabled for all the other options like visibility? For example I have a scene where I like to change the visibility of some objects, but I don't need a live update of this objects.
So it could be good if you create two Octane mesh nodes - one for not-live geometry and one for live geometry. I suppose so we will see more object based options in the future over the years. To mark all this object as live objects will slow down scene updates.
Posted: Thu Feb 18, 2016 8:38 am
by Micha
Hi Paul, couldn't you make the visibility option and all the other stuff independent from the live status? It are different things, not needed together always.
Posted: Thu Feb 18, 2016 10:00 am
by face_off
No, because all Rhino geometry items which are not "Live" are stored together in the one single Octane Mesh node.
