OUT OF DATE PLUGIN ARCHICAD 19? help!!
Posted: Sun Nov 01, 2015 2:11 am
by aaron44
Hi All - any help please -
am running archicad 19 3003
plugin - OctaneRender for ArchiCAD 19 2.23.2.51 (64 bit)
and getting the following error in the add ons manager
"The file is an outdated Add-On that cannot be used with this ArchiCAD version."
Re: OUT OF DATE PLUGIN ARCHICAD 19? help!!
Posted: Sun Nov 01, 2015 2:43 am
by face_off
Can you try the latest TEST build pls?
viewtopic.php?f=56&t=44563
Posted: Sun Nov 01, 2015 3:26 am
by aaron44
No luck with this build
OctaneRender_for_ArchiCAD19_2_24_2_55_64bit
Posted: Sun Nov 01, 2015 3:46 am
by aaron44
getting the same "out of date" error
Posted: Sun Nov 01, 2015 4:47 am
by aaron44
tried reverting back to Archicad 18 3006 and still had the same out of date issues with the latest build of the octane render plugin, Frustrating - deadline tomorrow....
Posted: Sun Nov 01, 2015 9:04 am
by face_off
Hi - sorry you are having these issues. I haven't had any other reports of this with the latest TEST release, so I believe you are the only user experiencing this issue. What NVidia driver version are you running pls? Does Octane Standalone work for you? What was the last version of the plugin that did work for you?
Posted: Sun Nov 01, 2015 11:44 am
by aaron44
Legend - thanks for bringing up the nvidia driver - that did it - all nighter ahead to catch up but at least I'll have octane under my belt!
Posted: Sun Nov 01, 2015 12:13 pm
by aaron44
turned out I had too many vertices?!!
Have to revert to built in rendering engine - I thought this was set higher recently? Is it configurable in the current plugin?
Posted: Sun Nov 01, 2015 9:56 pm
by face_off
I don't see how the number of vertices in the scene would effect the ability for AC to load the Octane addon. Are you able to do a test pls....start AC, load a blank scene, does the Octane plugin get loaded? Restart AC and load your large scene, does the Octane plugin get loaded?
Also - what graphics card are you running pls? How much VRAM does it have?
