F10 render passes not saving
Posted: Wed Oct 28, 2015 5:43 pm
by pryzm
Strange thing happening, I've been rendering passes the last few weeks without issue but in one particular project (LW scene) it's not rendering out the passes. I've checked all the usual settings to make sure things are rendering, but nothing is any different than the scenes I've been working with except the location of the files (and even then it's only a different sub-directory on the same drive.
It seems like it's just a setting I'm missing, but can't seem to find it. Any thoughts?
thanks!
bruce
Re: F10 render passes not saving
Posted: Wed Oct 28, 2015 5:50 pm
by pryzm
okay, so I had a thought. I tried a different directory and realized the image being saved didn't have a frame number (it was saving the first frame). So I loaded up the image in irfanview and waited until LW had "rendered" a few frames then loaded that image in a separate irfanview window. I AB'd the two images and noticed that LW was saving each rendered image with the same name. Auto Frame Advance is checked, but it keeps rendering over the top of the same image (without number the frames)
Anyone else run into this?
thanks,
bruce
Posted: Wed Oct 28, 2015 5:57 pm
by juanjgon
Weird issue, can you send me the .lws file?
Posted: Wed Oct 28, 2015 6:04 pm
by pryzm
yup, thanks juanjgon
bruce
Posted: Wed Oct 28, 2015 6:22 pm
by juanjgon
The problem are the dot characters in the filename. If you replace your "ww.turtle.01.v001." base name for something like "ww-turtle-01-v001", the plugin works fine.
I can't see any problem in my code, so this could be a limitation of the Octane save functions. Do you know if the passes are working in other early plugin versions (saved as discrete PNG files) with dots in the file name?
Posted: Wed Oct 28, 2015 7:15 pm
by pryzm
hmmm...really strange.
I changed the filename to underscores "ww_turtle_01_v001" and it did the same thing. REALLY weird. Also, just for kicks, I selected a bunch of passes to render as well (I was only rendering a Main pass) and it doesn't save ANY of those files.
bruce
edit:
I used to use "dot" names a while back (previous to Octane) and had only decided to try it again on this particular scene. The other scenes I have did use underscores. I was hoping that would fix it, but it's still the same problem as noted above.
Posted: Wed Oct 28, 2015 7:27 pm
by juanjgon
And have you removed the last dot in the file name? ... the last character in the file name is a dot, that can also be a problem.
Posted: Wed Oct 28, 2015 7:51 pm
by pryzm
yowza! nice catch on that! It was still in there, sneaky little bugger...that seemed to do it. So is this the normal way it handles the dots? Seems like back in the day they were all dots before we started using underscores...
thanks, juanjo, once again you saved my bacon!
bruce
Posted: Wed Oct 28, 2015 8:01 pm
by pryzm
One other crazy thing that hasn't really bothered me (I just work around it) is the naming of the render passes. I have it set to:
Name_pass_0001
but it renders out:
ww_turtle_01_v001_Main-0000
where right after the pass name (in this case "Main") is puts a minus sign as opposed to an underscore.
would this be an Octane thing, or part of the plugin?
thanks,
bruce
Posted: Wed Oct 28, 2015 9:30 pm
by juanjgon
Yes, this is a bug in the plugin, but only happens with the Main pass, all other passes should have the right format.
I will fix it for the next release, thanks for reporting!
