Page 1 of 2
House interior - From Scratch
Posted: Tue Jan 25, 2011 8:23 am
by Sixthlaw
Hey guys!
For this scene I did something I have not done previously, that is too model the entire scene with only one image. This was a new way of doing things (instead of a floor plan etc.) but was a fun, learning experience. This is the Picture that I based my modelling off.
So I began by adding the simple base plane that the entire scene would be built off and getting it to line up correctly with the image's perspective. Here is an image of the lining up; note that the blend file had been played around with alot since when I first lined it up so its a bit out of place.
Once the ground works were down pat, I stuck a simple texture on the floor and walls, and tested how the lighting would work with only two windows, in octane.
I was not entirely happy with the results as the room seemed to be out of proportion, which was fixed when objects to actually compare proportion to were added into the scene. The couch I got online as I couldn't be bother modelling one! I know lazy right? So after adding most of the objects, I created a clay render in octane, just to test the dynamics, composition, and for the last time make sure, as well I could, that the objects in the scene were to the right proportions.
After doing this, I got to adding a few more objects and then got stuck in to some Uv-mapping goodness. Good thing about interior scenes is that Uv-mapping, is almost always, a very basic task as objects are normally VERY BASIC. So after applying a few textures here and there, I chucked it into octane and let her crunch away for a bit.
Direct-Lighting
Raytraced
So I got up to make myself a coffee, and pointed my fan at the back of the computer (just for good measure:P). But upon arriving back at my computer, I met a sorry scene. Yes, it is ok I guess... But look at the lighting! Look at all the different points of focus! Look at the bad lack of lighting in the far room... So, much to my displeasure, this project is still a work in progress.
A great way of deciding the design quality of any image is to change it black and white. After doing this I began to realize many of the problems I needed to fix.
So that is where I am up to!
What would be awesome is if all you guys gave me tips and advice on how to make my image look that little bit better, and make it closer the original reference image!:D
sixthlaw
Re: House interior - From Scratch
Posted: Tue Jan 25, 2011 10:37 am
by gaua
Interesting techniqe. Good for training.
About light. I think it is too sharp. It would look better with some diffusion but octan didn't like it.
Try some dfferent glass in windows.
Posted: Tue Jan 25, 2011 2:37 pm
by Sixthlaw
Ah thanks Gaua! I was trying to get the light to be less sharp by increasing the Turbulence, but it was not working; glass should be a great fix! I will put in an updated render in a bit:)
All comments and advice much wanted!
Sixthlaw
Posted: Tue Jan 25, 2011 3:49 pm
by Sixthlaw
Ok so I did a very quick test with the glass!
The light was definitely less sharp, but I can't seem to control the amount of light that passes through the glass. This is just a bit annoying. The normals of the glass are facing into the scene, and I have tried both thick and plane-thin glass. These are the settings for my glass, please help me if you can!
Posted: Tue Jan 25, 2011 3:53 pm
by dave62
good work!
sort of a nice camera mapping technic you use.
if the backround image res is big enough, you could use it also for texturing after a lil 2d image clone and retouch work........:))))))
Posted: Tue Jan 25, 2011 3:57 pm
by Sixthlaw
Thanks Dave!
Yeah I did do that very early on haha! Uv-map project-from-view aye? :P
Posted: Wed Jan 26, 2011 10:55 am
by Sixthlaw
Any help with the glass?
Posted: Wed Jan 26, 2011 10:59 am
by john_petrucci
Sixthlaw wrote:Ok so I did a very quick test with the glass!
Try to setting a low opacity value ;)
my personal question, what is the value power of the
sunlight???
Posted: Wed Jan 26, 2011 11:05 am
by ttaberna
Posted: Wed Jan 26, 2011 11:46 am
by Sixthlaw
I'm not authorized to view that forum. I am running the demo version of Octane. Could you copy paste its contents please.
As for the changing opacity and the power value of the sunlight, neither gave me control of light passing through the glass.
