Page 1 of 2
DOH! I am still having alembic texture issues
Posted: Tue Oct 20, 2015 1:21 am
by LuvMultimedia
She looks great here
not sure what happens here -- am I changing the bump in the right area/section?
I know I am probably becoming a pain but I am still having alembic textures issues. Weird cause when I pull her in as a simple obj. she looks great--its only when I try to use the textures on the alembic coverage that I have issues. Not sure what I am doing wrong. I have tried both attaching the spaghetti nodes and dropping the obj in and applying textures that way -- nothing seems to work....
I put the picture here to make sure I am changing this in the right spot--am I supposed to change the bump in the mesh area??? I am so confused...or just stooped. Or both.
Re: DOH! I am still having alembic texture issues
Posted: Tue Oct 20, 2015 12:51 pm
by bepeg4d
Yes, as you can see the bump is set at 1 that is a very high value for Octane
Have you correct the materials in DAZ before exporting?
What happen to the bump if you export in orbx directly from DAZ?
The scale is correct for the alembic file?
ciao beppe
Posted: Tue Oct 20, 2015 1:19 pm
by LuvMultimedia
bepeg4d wrote:Yes, as you can see the bump is set at 1 that is a very high value for Octane
ciao beppe
The materials look awesome in Daz--do you think it would work best if I did some tweaking prior to exporting...?
If I export the orbx directly the textures look terrific -- it sonly when I exchange the geneis object with the alembic and put textures on them that they look messed up. I have tried taking the values down to no avail...it still looks weird.
Also--I was trying to render test animations (pngs frames) but can't seem to get the animation to progress. It creates one still out of 230 plus frames. Here's my render settings --am I doing something wrong again?
Posted: Tue Oct 20, 2015 1:22 pm
by LuvMultimedia
LuvMultimedia wrote:bepeg4d wrote:Yes, as you can see the bump is set at 1 that is a very high value for Octane
ciao beppe
If I export the orbx directly the textures look terrific -- it sonly when I exchange the geneis object with the alembic obj and put textures on the animate .abc that they look messed up. I have tried taking the values down to no avail...it still looks weird.
Posted: Tue Oct 20, 2015 2:01 pm
by bepeg4d
mmm, the only strange thing that I see in your screenshot is the "!" in the path. Please, try to avoid special characters in the path.
Could you share a simple scene with me (here or via private message)? I would like to make some tests based on one of your DAZ scene
ciao beppe
Posted: Tue Oct 20, 2015 6:11 pm
by LuvMultimedia
bepeg4d wrote:mmm, the only strange thing that I see in your screenshot is the "!" in the path. Please, try to avoid special characters in the path.
ciao beppe
would you -- that would be awesome....
Posted: Tue Oct 20, 2015 6:27 pm
by LuvMultimedia
ciao beppe
Okay, so what it looks like is the file j keeps being over written--instead of writing mirrors 1, mirrors, 2, mirrors 3, it keep writing mirrors over and over...is there a lua script fix for that? If so could you take me through the process. I don't know anything about lua scripts but I think that must be some kind of glitch and that may be the only way to fix it....
Posted: Wed Oct 21, 2015 7:54 am
by bepeg4d
Apologies, my bad, looking better at your screenshot (and at the numerous post that you have made) it seems that you have completely destroyed the file name template
Fortunately it seems that other users have already brought you on the right track
Anyway, the default file name template is "%n_%f_%p.%e", where:
- %n is the name of the render target node,
%f is the frame number,
%p is the render pass name,
%e is the extention of the image file saved,
you can also add:
- %i render target index number,
%t time of the rendered image in h_m_s,
Please, next time avoid cross posting, it's hard to track your request and could be confusing for other new users, thanks
ciao beppe
Posted: Wed Oct 21, 2015 6:32 pm
by LuvMultimedia
Yeah, I do apologize...I'm like a poodle in a hot house when I get frustrated...I'll mind my manners next time. But I thank you...if only you live in GA I'd toast yah, drinks on me!
Posted: Thu Oct 22, 2015 1:42 pm
by bepeg4d
You are welcome
It's quite normal to get nervous when the things does not work as expected
Happy GPU rendering
ciao beppe
