901 SP2: Octane Viewport Slow
Posted: Sun Sep 13, 2015 3:32 pm
by jtmsf
Hi
I just downloaded 901 SP2 demo and noticed that octane's direct camera navigation is very slow on the docked viewport. I have both 901 and 801 installed and in the later the viewport is fine with very fast camera navigation.
Re: 901 SP2: Octane Viewport Slow
Posted: Tue Sep 15, 2015 11:52 am
by face_off
Do you have a separate video card as your display adapter? If I render and use the same card as the display adapter with Modo901, viewport navigation is very slow (because Modo901 using more graphics card resources for it's OpenGL display).
Posted: Tue Sep 15, 2015 9:06 pm
by Rafael-Vallaperde
I noticed the same, mainly with live meshes, like moving my light to create scene lighting.
801 works fine.
Posted: Tue Sep 15, 2015 10:52 pm
by face_off
Do you have Preferences->Octane->User Modo Render Cache ticked or unticked pls?
Posted: Wed Sep 16, 2015 4:11 pm
unticked
Posted: Wed Sep 16, 2015 10:44 pm
by face_off
I did some testing on this. I think the main issue is that now there can be multiple viewports, so the triggering mechanism to indicate there is a new render available is much more complex than the Modo801 version of the plugin. I will see what can be done to improve things. In the long-term, the plugin will move completely to the Modo901 Render Cache API which will internally change the live geometry refresh system which should improve things.
Posted: Thu Sep 24, 2015 7:54 am
by Dmi3ryd
I found that octane for modo plugin working much slower (delays) than Octane standart alone.
Render speed same (i did a lot of tests) but perfomance in plugin is much slower.
For example I saw how plugin working in Cinema 4d. It's same as in Octane standart alone.
My viewport working very good (fps).
Posted: Fri Sep 25, 2015 2:45 am
by face_off
Dmitry - this is pretty vague. If there are specific functions which are lagging, pls let me know, and provide a sample scene, so I can reproduce the delay and look for a resolution. In general, a lot of Mesh items will slow auto-updating and material updates considerably, because of the time required to process each Mesh item through the Modo API.
Posted: Fri Sep 25, 2015 7:50 am
by Dmi3ryd
Paul I'll try to write video with plugin and regular software. And difference between.
