SP2 is out!!
Posted: Thu Sep 10, 2015 5:30 pm
by Rafael-Vallaperde
Hopefully all those nasty bugs related to the rendercache should be gone. :D
Any idea on when we'll see a new version Paul?
Cheers!
Re: SP2 is out!!
Posted: Thu Sep 10, 2015 5:31 pm
Fix list:http://community.thefoundry.co.uk/support/MODO901_SP2_details.aspx
Re: SP2 is out!!
Posted: Thu Sep 10, 2015 10:24 pm
by face_off
The render artifacts are fixed in SP2, however there are still other issues (functional and stability), so I don't recommend using it yet.
Re: SP2 is out!!
Posted: Fri Sep 11, 2015 6:00 pm
alright, waiting for your new version.
Cheers
Re: SP2 is out!!
Posted: Fri Sep 11, 2015 8:42 pm
by face_off
The latest version of the plugin works with SP2. No need to wait.
Re: SP2 is out!!
Posted: Tue Sep 15, 2015 9:07 pm
But you mentioned that errors might be preset. should i wait for a SP3 then?
Sp2 resolves a lot of modo issues!
But if it start to cause me issues with octane i rather wait.
Re: SP2 is out!!
Posted: Tue Sep 15, 2015 10:49 pm
by face_off
Raf, SP2 resolves a lot of issues in Modo generally, and with the Render Cache API, so definitely worth updating to it. However there are still issues with the Render Cache, so leave it UNTICKED in the preferences (unless you specifically want to render the Modo Hair Shader, or proxies, references meshes, etc).
Re: SP2 is out!!
Posted: Wed Sep 16, 2015 4:15 pm
Sweet, thank you for clarifying Paul!
Re: SP2 is out!!
Posted: Wed Sep 16, 2015 7:45 pm
by LFedit
face_off wrote:Raf, SP2 resolves a lot of issues in Modo generally, and with the Render Cache API, so definitely worth updating to it. However there are still issues with the Render Cache, so leave it UNTICKED in the preferences (unless you specifically want to render the Modo Hair Shader, or proxies, references meshes, etc).
This will make proxies and reference meshes work? Even with Octane overrides? I didn't know that.
Re: SP2 is out!!
Posted: Wed Sep 16, 2015 10:38 pm
by face_off
It /should/ although there are some limitations. https://docs.otoy.com/#42Modo901%20Specifics
