Octane info stats showing up in rendered frames
Posted: Thu Aug 27, 2015 8:56 pm
by CCIDgfx
I'm having an issue where the Octane render status bar is showing up in my rendered frames. What is causing this and how can I fix it?
Thank You
Re: Octane info stats showing up in rendered frames
Posted: Thu Aug 27, 2015 9:48 pm
by aoktar
Is it from picture viewer?
Posted: Thu Aug 27, 2015 10:06 pm
by CCIDgfx
Yes...every 3rd frame or so.
Posted: Thu Aug 27, 2015 10:11 pm
by aoktar
It should disappear when frame finished or cancelled.
Posted: Thu Aug 27, 2015 10:14 pm
by CCIDgfx
I was rendering a 250 frame animation. When I was compositing in AE is when I noticed it flickering through the frames. I re-rendered the sequence with no issue. But that was an hour on a deadline I wasn't counting on. What else could cause that?
Posted: Thu Aug 27, 2015 10:19 pm
by aoktar
Maybe an object/tag of other plugin caused to break frame rendering or any cuda error. Hard to estimate without testing.
Posted: Thu Aug 27, 2015 10:24 pm
by CCIDgfx
No other plugins or object tags being used. Only 2 Octane lights and an environment. It was a pretty simple scene. No motion and only a couple MoText objects. I can upload the c4d file if it will help.
Posted: Thu Aug 27, 2015 10:44 pm
by aoktar
I'll test it when i'm free. But can't be possible to generate same results. What was your plugin version and os?
Thanks.
Posted: Thu Aug 27, 2015 10:45 pm
by CCIDgfx
Thank You
