Maya IPR Crash - large image
Posted: Thu Aug 06, 2015 8:24 pm
by gabrielaraujo712
Hi folks!
Anyone know why maya don't render IPR with High res image setup.
Maya 2015 with Octane 2.23.2 - 7.8
My setup is: 4446x3394 300 dpi with some render passes.
Re: Maya IPR Crash - large image
Posted: Fri Aug 07, 2015 11:49 pm
by danielsiegl
Hey Gabriel,
I rendered even higher resolutions and it worked fine in IPR.
I think more than 8K res wasn't possible with my 3Gig 780's but possible with the 6gig Titan.
So i guess it must be something else then hires.
try verbose mode and see the log files...
Best!
Daniel
Posted: Mon Aug 10, 2015 2:06 pm
by gabrielaraujo712
Thanks Daniel.
I'll check out.
Posted: Mon Aug 10, 2015 3:53 pm
by gabrielaraujo712
Verbose mode was checked, but still not render the image with IPR.
My Log.
// Warning: Render view: Selected region is too small //
// Octane: starting render, frame 1... //
// ****************************** THIN LENS CAMERA ********************************* //
// Name: Beer_Render_Octane_Bar02:cameraShape1 //
// Orthographic: 0 //
// Film width: 35.999928, Focal length: 50, calculated FOV: 39.597679 //
// Aperture: 100 //
// Aperture edge: 2.4 //
// Distortion: 0 //
// Auto-focus: 0 //
// Focal depth: 140.699997 //
// Persp. correction: 0 //
// Stereo mode: 1 //
// Stereo output: 0 //
// Stereo distance: 0.02 //
// Near clip depth: 1e-007 //
// Pixel aspect ratio: 1 //
// Aperture aspect ratio: 1 //
// Camera: X: -21.425633, Y: 23.12563, Z: 141.561774 //
// Target: X: -26.504543, Y: 23.826962, Z: -3.879192 //
// Up: X: 0.000168185, Y: 0.999988, Z: 0.00481617 //
// IMAGER: //
// Exposure: 5 //
// Highlight compression: 0 //
// Gamma: 1 //
// Response: 105 //
// Vignetting: 0.3 //
// Saturation: 1 //
// Hot pixel removal: 1 //
// Premultiplied alpha: 0 //
// Min display samples: 1 //
// Dithering: 0 //
// White saturation: 0 //
// POSTPROCESSOR: //
// Enabled: 0 //
// Bloom power: 1 //
// Glare power: 0.1 //
// Glare ray count: 3 //
// Glare angle: 15 //
// Glare blur: 0 //
// Spectral intensity: 0 //
// Spectral shift: 2 //
// 0:00 Octane kernel set: Path Tracing //
// Octane: Scene scale factor: 1 //
// 0:00 Device "1: GeForce GTX 780 (compute model 3.5)" is ENABLED //
// 0:00 Device "2: GeForce GTX 780 (compute model 3.5)" is ENABLED //
// 0:00 Device "3: GeForce GTX 780 (compute model 3.5)" is ENABLED //
// Network rendering is DISABLED //
// 0:00 Octane engine: creating meshes... //
// 0:00 Gathering Mesh objects data... //
// Octane: Object "Beer_Render_Octane_Bar02:beerCupShape" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:beerLiquidCupShape" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:FOAM:ZBrush_defualt_groupShape" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:loftedSurfaceShape1" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:pPlaneShape1" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:group3Shape" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:polySurfaceShape2" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:rotuloShape" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:gravataShape" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:polySurfaceShape4" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:glass2:glassLiquid1Shape" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:glass2:polySurfaceShape1" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:pSphereShape1" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:pSphereShape2" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:mesaShape" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:pSphereShape3" is not visible, skipping... //
// Octane: Object "Beer_Render_Octane_Bar02:mesa1Shape" is not visible, skipping... //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:liquidShape //
// ****************************** MESH DATA ****************************** //
// Number of vertices: 422 //
// Number of normals: 839 //
// Number of UVs: 479 //
// Number of polygons: 440 //
// Number of vertex indices: 1720 //
// Number of normal indices: 1720 //
// Number of UV indices: 1720 //
// Number of material indices: 440 //
// 0:00 ...done setting Mesh data in 0:00 //
// 0:00 Voxelizing... //
// 0:00 ...voxelized in 0:00 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:BraileShape //
// Number of vertices: 468 //
// Number of normals: 594 //
// Number of UVs: 468 //
// Number of polygons: 405 //
// Number of vertex indices: 1620 //
// Number of normal indices: 1620 //
// Number of UV indices: 1620 //
// Number of material indices: 405 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:bottleBaseShape //
// Number of vertices: 11076 //
// Number of normals: 17892 //
// Number of UVs: 11076 //
// Number of polygons: 10792 //
// Number of vertex indices: 43168 //
// Number of normal indices: 43168 //
// Number of UV indices: 43168 //
// Number of material indices: 10792 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:tampaShape //
// Number of vertices: 1450 //
// Number of normals: 2856 //
// Number of UVs: 1666 //
// Number of polygons: 1386 //
// Number of vertex indices: 5544 //
// Number of normal indices: 5544 //
// Number of UV indices: 5544 //
// Number of material indices: 1386 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:OuterBottle_NewUVShape //
// Number of vertices: 1142 //
// Number of normals: 2078 //
// Number of UVs: 1306 //
// Number of polygons: 1160 //
// Number of vertex indices: 4600 //
// Number of normal indices: 4600 //
// Number of UV indices: 4600 //
// Number of material indices: 1160 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:glass2:glass1Shape //
// Number of vertices: 1382 //
// Number of normals: 1428 //
// Number of UVs: 1506 //
// Number of polygons: 1403 //
// Number of vertex indices: 5566 //
// Number of normal indices: 5566 //
// Number of UV indices: 5566 //
// Number of material indices: 1403 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:glass2:ZBrush_defualt_groupShape //
// Number of vertices: 24578 //
// Number of normals: 24578 //
// Number of UVs: 25123 //
// Number of polygons: 24576 //
// Number of vertex indices: 98304 //
// Number of normal indices: 98304 //
// Number of UV indices: 98304 //
// Number of material indices: 24576 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:ferroShape //
// Number of vertices: 240 //
// Number of normals: 320 //
// Number of UVs: 294 //
// Number of polygons: 240 //
// Number of vertex indices: 960 //
// Number of normal indices: 960 //
// Number of UV indices: 960 //
// Number of material indices: 240 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape1 //
// Number of vertices: 320 //
// Number of normals: 428 //
// Number of UVs: 428 //
// Number of polygons: 318 //
// Number of vertex indices: 1272 //
// Number of normal indices: 1272 //
// Number of UV indices: 1272 //
// Number of material indices: 318 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape2 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape3 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape4 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape5 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape6 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape7 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape8 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape9 //
// 0:00 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape10 //
// 0:01 ...done setting Mesh data in 0:01 //
// 0:01 Voxelizing... //
// 0:01 ...voxelized in 0:00 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape11 //
// 0:01 ...done setting Mesh data in 0:00 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape12 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape13 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape14 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape15 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape16 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape17 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape18 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape19 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:Gabriel_20150805_2010:pPlaneShape20 //
// 0:01 Setting Mesh data of mesh: Beer_Render_Octane_Bar02:Barrel:tampaShape //
// Number of vertices: 684 //
// Number of normals: 756 //
// Number of UVs: 684 //
// Number of polygons: 110 //
// Number of vertex indices: 900 //
// Number of normal indices: 900 //
// Number of UV indices: 900 //
// Number of material indices: 110 //
// 0:01 ...done, //
// 0:01 Gathering Subdiv objects data... //
// 0:01 ...done, //
// 0:01 Gathering Octane Light objects data... //
// 0:01 ...done, //
// 0:01 Gathering Instancer objects data... //
// 0:01 ...done, //
// 0:01 Gathering Hair objects data... //
// 0:01 ...done, //
// 0:01 Setting Mesh data of general mesh //
// ****************************** GENERAL MESH DATA ****************************** //
// Number of vertices: 2740 //
// Number of normals: 4020 //
// Number of UVs: 3160 //
// Number of polygons: 2560 //
// Number of material indices: 2560 //
// Number of vertex indices: 10240 //
// Number of normal indices: 10240 //
// Number of UV indices: 10240 //
// 0:01 ...done creating meshes //
// 0:01 Octane mesh data is set to render engine. //
// 0:03 Octane: Scene export complete. //
// 0:03 Setting refresh rate to 100 ms... //
// 0:03 ...done //
Posted: Fri Aug 14, 2015 12:09 pm
by Jolbertoquini
gabrielaraujo712 wrote:Hi folks!
Is look huge for me just on IPR in maya?? try to use the section render if you deactivate "use pick focus" and then render only where you need see the details. Also resolution on maya set 72 and then in photoshop change to 300 dpi.
this may help you out.
some times aswell is memory cause of the passes. activate for IPR only the one you want see then for final render yeah activate all for the cmd render.
for me is working fine , you still can render tiled aswell to avoid the extra memory need
use lens shift option and aperture divide by 2.
Cheers
JO
Posted: Fri Aug 14, 2015 8:09 pm
by gabrielaraujo712
Thanks Jolbertoquini.
I'll try
Posted: Mon Aug 17, 2015 9:11 am
by Jolbertoquini
gabrielaraujo712 wrote:Thanks Jolbertoquini.
I'll try
No problem if you need any help to understand how to render tiled I could explain better but is quite easier if you look around on the forum will find on C4D plug section.
just need set for example tiled by 2x2 half of the image size and the key lens shift in 4 frames, 0.5,05 for frame1,-0.5,05 for frame2, -0.5,-05 for frame3, 0.5,-05 for frame4
and camera aperture divide by 2. and render the sequence.
