Page 1 of 2
Alpha
Posted: Thu Aug 06, 2015 6:02 pm
by nbeyond
Hi there,
i just want to put a image on the bottle - it works more or less but i "lose" the texture/material beneath =/
there is the glas material and with a polygon selection i put the other material (image with alpha/opacitiy) on the bottle
tryed mixed material but that´s also no solution
greez
armin
Re: Alpha
Posted: Thu Aug 06, 2015 8:13 pm
by dotcommer
how did you go about your mix texture? That should be the right way to do it:
Create glass texture, and create the label texture (with an alpha channel). Put both materials into the mix texture, and in the amount, put your label's alpha channel.
Re: Alpha
Posted: Fri Aug 07, 2015 8:44 am
by nbeyond
i´m not sure if i´m missing something but still the same problem =/
Re: Alpha
Posted: Fri Aug 07, 2015 9:37 am
by aoktar
Don't use c4d bitmaps. Imagetexture is better with extra parameters.
Re: Alpha
Posted: Fri Aug 07, 2015 10:12 pm
by dotcommer
nbeyond wrote:i´m not sure if i´m missing something but still the same problem =/
Oh I see the issue. Like Ahmet just mentioned above, you're using a C4D image texture. You need to use Octane Image Texture for the amount. In amount, choose "image texture" from the octane materials, then load in your decal alpha channel into that. Also keep in mind Octane doesn't like things like png's with transparency. Convert your alpha to a black and white image. Hope that helps.
Re: Alpha
Posted: Fri Aug 07, 2015 10:20 pm
by aoktar
dotcommer wrote:nbeyond wrote:i´m not sure if i´m missing something but still the same problem =/
No need to convert pngs. Just select "alpha" in mode to use alpha.
Re: Alpha
Posted: Fri Sep 18, 2015 1:00 am
by bendingpixels
Hey guys, how did you get the label to show up flat mapped onto thefront of the bottle? Octane doesn't seem to honor the C4D projection techniques.
Re: Alpha
Posted: Fri Sep 18, 2015 1:01 am
by bendingpixels
Sorry for the second post... forgot to turn on "notify" for my last question
Re: Alpha
Posted: Fri Sep 18, 2015 1:07 am
by aoktar
bendingpixels wrote:Hey guys, how did you get the label to show up flat mapped onto thefront of the bottle? Octane doesn't seem to honor the C4D projection techniques.
Propably doing some mistake. It's of course works with most projection types. Any sample scene to show what's the problem?
Re: Alpha
Posted: Fri Sep 18, 2015 2:12 am
by bendingpixels
Thanks for getting back to me.. .LOL user error is way more than most of my problems. I attached the image i've been working on.
The logo on the mug is stuck there using the mix texture, but I got it into position by screwing around with the UV Transform node for a long time until it finally showed up in kinda the right place.
Are you saying that the regular C4D projections should work? I tried that and got no results. Meaning that the image didn't show up on the object unless it was set to UVW.
