where is default rende target???
Posted: Fri Jul 24, 2015 6:03 pm
by morphious2013
No mater what I do, refresh textures in poser, refresh textures in Octane, the eyes always render blue, and any hair texture changes I make do note show up in octane, but they do in Poser. using the plug that ends in .48 to be able to select texture nodes without 60 second delay. I guess my render target is corrupt from switching back and forth between plugin versions.
Re: where is default rende target???
Posted: Fri Jul 24, 2015 8:51 pm
by face_off
I doubt it is picking up the wrong defaults. Is this happening on every figure and hair prop, or only some? Does it happen with Roxie? Can you post the Octane Material tab showing the eye material pls?
Posted: Fri Jul 24, 2015 9:06 pm
by morphious2013
If I take a texture into photoshop and add some grey streaks to hair, and reload textures in Poser, and Octane, it shows the proper texture in the Octane node, but does not render the hair with the grey streaks I added.
Posted: Sat Jul 25, 2015 3:29 am
by face_off
Is this related to the original issue posted in this thread? I am confused!
Posted: Mon Jul 27, 2015 11:07 am
by morphious2013
Same issue. Eeyes only render blue, and adding grey streaks to hair do not show up in octane render. All related in my opinion. That's why maybe my render target is corrupt. Where is it again? Thanks.
Posted: Mon Jul 27, 2015 11:17 am
by TRRazor
I can hardly believe that this is related to your default rendertarget.
If you point Octane to a diffuse texture and the texture is shown as sitting in the node - it should show up in the render, simple as that.
Have you maybe tried changing your rayepsilon value?
I've noticed hiccups similar to the ones you mentioned above when setting the rayepsilon to extremely high / low values.
Posted: Mon Jul 27, 2015 2:12 pm
by face_off
Would it be possible to post some screenshots of the problems you are having pls? I doubt your rendertarget is the problem, but if you want to reset it, the location of these settings are detailed at
http://render.otoy.com/universe.php#44Render%20Settings in the "Load/Save as Default" section.
