OctaneRender 2.2 for LightWave Production build 2.25
gordonrobb
Ah, ok. No worries. Thanks for the quick reply :)
MrFurious
An update on the IPR weirdness I've been experiencing. This only seems to happen if I rename the material before editing the Octane materal.. in which case I have to reload IPR to see changes. If I don't rename the material, or rename the material After setting up the Octane material, all is good and IPR behaves as it should.
Correction.. EVERY time I rename the surface, IPR needs to be reloaded to see changes in the Octane Material
Dino Inglese
CG Artist
Melbourne Australia
Octane build 4.04.0.145
juanjgon
MrFurious wrote:An update on the IPR weirdness I've been experiencing. This only seems to happen if I rename the material before editing the Octane materal.. in which case I have to reload IPR to see changes. If I don't rename the material, or rename the material After setting up the Octane material, all is good and IPR behaves as it should.
Yes, if you rename materials you need to reload the scene in the IPR. Currently the plugin can't change the internal material names in the Octane scene, and as you can see the picking and materials editing could fail. I will check this issue for Octane 3 to see if it can be fixed.
MrFurious
I've never noticed this problem before this build- was using Octane for Lightwave 2.16.0 previously, has it always been that way?
Dino Inglese
CG Artist
Melbourne Australia
juanjgon
MrFurious wrote:I've never noticed this problem before this build- was using Octane for Lightwave 2.16.0 previously, has it always been that way?
Yes, as far I know ;) ... perhaps in the old plugin versions, before the 2.x releases, rename the objects didn't affect the picking because the plugin was using a custom raycasting code to pick over the Layout scene. Now the plugin uses the native Octane picking functions over the Octane scene, and I am sure that if you rename the surfaces without reload the scene, you are going to have side effects in the IPR.
Anyway I will review all this code to know what is happening and if it is possible support materials renaming while the IPR is rendering.
juanjgon
A preview of the upcoming LiveDB support in the OctaneRender for LightWave plugin.
[vimeo]http://www.vimeo.com/132951342[/vimeo]
3dworks
very nice news :-)
what are the other goodies in the bag? ;-)
cheers and good luck with the coding...
markus
atnreg
WOOOOOOOW! :mrgreen:
When this feature will be available in beta or final version? ;)
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun :)
gordonrobb
Looks great. Is this a 2.x feature?
Lewis
Great stuf fJuan, keep them coming :).
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
