OctaneRender™ for Blender 2.23.2 - 8.6 Linux [OBSOLETE]
Posted: Thu May 28, 2015 3:39 am
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v8.6 Linux (101.0MB autoinstaller file)
For network slave and daemon please download standalone installer here:
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
- Fixed the animation rendering bug: rendering of sequence always stopped after the frame having meshes with degenerate polygons or singular matrices. (thanks to aLeXXtoR for report)
- A lot of improvements of the scene translation speed for single frames and animation sequences. Especially may be noticeable for animation of the scenes having lot of unpacked image textures (packed are always slower).
Installation:
# OctaneServer &DOWNLOAD
