Proxy Objects not working with objects from archicad
Posted: Sun May 24, 2015 9:46 pm
Unfortunately i have to seek again for your help grand octane archicad masters!
My Problem is relativly simple: evry object i export from archicad to an obj file so i can use it as proxy is not working as proxy. when i export an geometry out of, lets say, sketchup its working perfect.
there are some error messages that light up, or it dosent give me an error and the proxy object wont render.
here let me show you waht im doing here, maybe there is something wrong allready:
Attachement 1:
As you can see i have a simple cuboid in archicad. created in a complete new archicad file with nothing else in it.
Attachment 2:
I export that cubiod as object
(saveing with layers - surfaces or elements - surfaces have the same effect)
Attachment 3:
I create a cubiod in sketchup
Attachment 4:
Export cubiod as .obj file
Attachment 5:
I have to chairs, working as proxys
obj from sketchup is working as itended
obj from archicad not
attachement 6:
here is the error that ocurs normaly. the surface that is stated here does not exist. not in the mtl file or in the archicad. i dont know from where this surface could possible come from. furthermore did i check the .mtl file:
# FILE:OBJECT_FROM_ARCHICAD.obj
newmtl GDLM1_SHADOW_MATERIAL
Ka 0.228885 0.228885 0.228885
Kd 0.228885 0.228885 0.228885
Ks 0 0 0
illum 2
Ns 0
newmtl GDLM2_OPAQUE
Ka 0 0 0
Kd 0 0 0
Ks 0 0 0
illum 2
Ns 0
newmtl PAINT_-_LIGHT_GRAY
Ka 0.467765 0.467765 0.467765
Kd 0.540235 0.540235 0.540235
Ks 0.366667 0.366667 0.366667
illum 2
Ns 11
newmtl PEN_MATERIAL93
Ka 0.592401 0.592401 0.291051
Kd 0.592401 0.592401 0.291051
Ks 0 0 0
illum 2
Ns 0
the manual states "Edit the MTL file and change any lines with “map_Kd to “map_d”. in the case of the cubiod those lines does not exist. if i have them in a mtl file, changing those wont make any effect.
does someone know how to solve this issue?
i realy would like to have a nice forrest =(
Attachement 1:
Attachment 2:
Attachment 3:
Attachment 4:
Attachment 5:
attachement 6:
Ks 0 0 0
illum 2
Ns 0
newmtl GDLM2_OPAQUE
Ka 0 0 0
Kd 0 0 0
Ks 0 0 0
illum 2
Ns 0
illum 2
Ns 11
Ks 0 0 0
illum 2
Ns 0
