JimStar wrote:Please enable the "Verbose mode" in Octane global settings and attach here the batch render log file.
5/19/2015
Starting "C:\Program Files\Autodesk\Maya2015\bin\mayabatch.exe"
Error: file: C:/ProgramData/Autodesk/ApplicationPlugins/MayaBonusTools/Contents/scripts-2015/bonusToolsMenu.mel line 1546: UI commands can't be run in batch mode.
File read in 0.5 seconds.
Result: D:/p4/Interactive/UE4Vortex/Source Art/Labs/StereoDome_pat/octane1__6468.mb
Octane: Starting in batch mode...
Octane: starting animation of frame 1...
Octane: Scene scale factor: 1
0:01 Device "1: GeForce GTX 980 (compute model 5.2)" is DISABLED
Warning: Octane: No CUDA devices choosen to render on. Rendering on the first one: GeForce GTX 980 (compute model 5.2)
Network rendering is DISABLED
0:01 Octane engine: creating meshes...
0:01 Gathering Mesh objects data...
0:01 Setting Mesh data of mesh: pSphereShape4
****************************** MESH DATA ******************************
Number of vertices: 382
Number of normals: 382
Number of UVs: 439
Number of polygons: 400
Number of vertex indices: 1560
Number of normal indices: 1560
Number of UV indices: 1560
Number of material indices: 400
0:01 ...done setting Mesh data in 0:00
0:01 Voxelizing...
0:01 ...voxelized in 0:00
0:01 ...done,
0:01 Gathering Subdiv objects data...
0:01 ...done,
0:01 Gathering Octane Light objects data...
0:01 ...done,
0:01 Gathering Instancer objects data...
0:01 ...done,
0:01 Gathering Hair objects data...
0:01 ...done,
0:01 Setting Mesh data of general mesh
****************************** GENERAL MESH DATA ******************************
Number of vertices: 4884
Number of normals: 6052
Number of UVs: 2350
Number of polygons: 4999
Number of material indices: 4999
Number of vertex indices: 19428
Number of normal indices: 19428
Number of UV indices: 19428
0:01 Voxelizing...
0:01 ...done creating meshes
0:01 Octane mesh data is set to render engine.
****************************** PANORAMIC CAMERA *********************************
FOV X: 360
FOV Y: 180
Kepp upright: 0
Stereo output: 3
Stereo distance: 0.0625
Stereo dist. falloff: 0.02
Blackout lat: 90
Pan type: cylindrical
Near clip depth: 0.01
Camera: X: 0, Y: 0, Z: 0
Target: X: 0, Y: 0, Z: -1359.338995
Up: X: 0, Y: 1, Z: 0
IMAGER:
Exposure: 1
Highlight compression: 0
Gamma: 1
Response: 105
Vignetting: 0.191011
Saturation: 1
Hot pixel removal: 1
Premultiplied alpha: 0
Min display samples: 1
Dithering: 0
White saturation: 0
POSTPROCESSOR:
Enabled: 0
Bloom power: 1
Glare power: 0.1
Glare ray count: 3
Glare angle: 15
Glare blur: 0
Spectral intensity: 0
Spectral shift: 2
0:01 Octane kernel set: Direct Lighting
0:01 Octane engine: Target node is set...
0:01 Octane: Scene export complete.
0:01 ...done
Octane: Refreshed image, 1 samples per pixel of 16000
Octane: Refreshed image, 3 samples per pixel of 16000
Octane: Refreshed image, 6 samples per pixel of 16000
Octane: Refreshed image, 8 samples per pixel of 16000
Octane: Refreshed image, 10 samples per pixel of 16000
Octane: Refreshed image, 11 samples per pixel of 16000
Octane: Refreshed image, 14 samples per pixel of 16000
Octane: Refreshed image, 16 samples per pixel of 16000
Octane: Refreshed image, 18 samples per pixel of 16000
Octane: Refreshed image, 20 samples per pixel of 16000
