Hair renders in Live Viewer but not in Picture Viewer
Posted: Mon May 18, 2015 2:16 am
by L_Sprangers
Hey everyone.
I'm using X-Particles trails to generate hair in Octane for Cinema 4D. It looks perfect in the Live Viewer, but when I go to render it in the Picture Viewer, nothing shows up at all. I made sure that the Octane Renderer tab comes after the Hair Render tab in the render settings. I looked all over the internet for suggestions but can't find a way to get this to work. Any help would be greatly appreciated!
Re: Hair renders in Live Viewer but not in Picture Viewer
Posted: Mon May 18, 2015 10:32 am
by aoktar
there is a explanation in manual about hair usage. And also some sample scenes to check. That will be enough to figure it.
Posted: Mon Sep 19, 2016 5:12 pm
by HuttonMiller3D
I am having this same issue and I haven't been able to figure it out based on the manual. It's pretty weak when it comes to explaining what to do. Plus I'm doing something a bit different. I have hair that I have made using a cylinder object that is used as an instance under the generate tab on my hair object. I'm doing it this way because I am going to be having my brush flow through the hair dynamically and I found that the collisions are nicer this way with actual geometry than just adding a collider tag to the hair.
I'm getting a render in my Live viewer but when i render to picture viewer it's blank. I can't seem to figure out what's going on. I'm sorry I can't attach a scene file for privacy purposes but I have pictures of all of my settings. If I missed something you need to see please let me know.
Live Viewer Result
Live Viewer Result
Picture Viewer Result
Object Manager
Object Manager
Object Manager.JPG (12.34 KiB) Viewed 2807 times
Hair Attributes
Hair Attributes
Render Settings
Render Settings
Render Settings.JPG (17.45 KiB) Viewed 2807 times
Posted: Tue Sep 20, 2016 10:21 am
by bepeg4d
Hi HuttonMiller3D,
weird, I have tried in several way to reproduce your issue without success, and I cannot see nothing strange in your settings :roll:
Here is a simpler example scene with instanced hairs, maybe you can find where is your issue :roll:
HairInstance_0001.c4d.zip
(741.06 KiB) Downloaded 204 times
ciao beppe
