OctaneRender™ for Blender 2.23.2 - 8.5 Linux [OBSOLETE]
Posted: Thu May 14, 2015 1:11 am
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v8.5 Linux (101.0MB autoinstaller file)
For network slave and daemon please download standalone installer here:
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
- Fixed the OctaneServer exit behaviour.
- Fixed the script error in world node editor.
- Improved the "Texture Paint" mode to support Octane image textures.
Installation:
# OctaneServer &DOWNLOAD
