Page 1 of 2
Change all bump map values at once on a figure???
Posted: Wed May 06, 2015 11:07 am
by morphious2013
Is it possible? Especially after adding RedSped SSS, it adds 3 to 4 materials for a single body part. Going part by part and increasing the bump maps is time consuming.
Any ideas? Thanks.
Re: Change all bump map values at once on a figure???
Posted: Wed May 06, 2015 11:22 am
by TRRazor
Paul implemented a function that makes it possible to scale all texturemaps of a highlighted material.
This however includes the diffuse, specular and opacity maps as well though, which would deliver bad results.
Manually increasing bump values in our RedSpec TGX shaders can only be done by fine adjusting them in each and every material node.
Sorry :/
Posted: Wed May 06, 2015 12:35 pm
by morphious2013
Yea, I figured as much, but was hopeful. Pain in the but. I wish Octane would match the bump values from poser and Your shaders would maintain those values when added. Oh well. Can't have it all.
Posted: Thu May 07, 2015 12:14 am
by face_off
You can adjust the bump value, then Copy the material, then Paste Node To All Skin Materials.
Posted: Thu May 07, 2015 10:21 am
by TRRazor
face_off wrote:Going part by part and increasing the bump maps is time consuming.
That's right !
Didn't think of that
Posted: Thu May 07, 2015 11:01 am
by morphious2013
but different body parts use different maps. also redspec has several bump nodes in one body part.
Posted: Fri May 08, 2015 12:35 am
by face_off
The "Paste Node To All Skin Materials" handles that - it doesn't replace the existing texturemaps - just the node values.
"Bump nodes", or "Image nodes in the Bump pin"? Pasting (retaining existing texturemaps) is not supported if a pin has more than one Image node. The bottom of the page at
http://render.otoy.com/forum/viewtopic. ... &start=220 discusses why you cannot paste a material which has more than one image node in the Bump pin.
Posted: Fri May 08, 2015 4:49 am
by TRRazor
Yes, we are using different bump values in the Material Mix nodes, since we felt that using the same value on the diffuse and specular materials, sometimes doesn't give the best results.
That is particularly true with the TGX tailored shaders, that (which is why they carry "tailored" in their name) are a truly customized experience.
Posted: Fri May 08, 2015 5:06 am
by face_off
That should be fine with the "Paste Node To All Skin Materials" menu option.
Posted: Fri May 08, 2015 8:35 am
by TRRazor
Which it is
