OctaneRender™ for Blender 2.23.1 - 8.2 OSX [OBSOLETE]
Posted: Fri May 01, 2015 6:12 am
The OSX version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just run autoinstaller file.
DOWNLOAD
Blender Octane Edition - v8.2 OSX (92.4MB autoinstaller file)
For network slave and daemon please download standalone installer here:
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
- New 2.23.1 engine.
- Merged with Blender 2.74.
- Added "Cube map" mode for panoramic camera.
- Don't use the stereo mode anymore to disable stereo in the thin-lens camera, but the stereo output setting. This makes the stereo settings of the panoramic and thin-lens cameras consistent.
- Added option "Pixel aspect ratio" to the thin-lens camera node, which allows you to render to a non-square pixel format (like NTSC or PAL).
- Added option "Aperture aspect ratio" to the thin-lens camera node, which allows you to stretch/squash the DOF disc.
- Added pin "Keep upright" to the panoramic camera node. If enabled, the up-vector is kept at (0, 1, 0).
- Added "Over-under" stereo mode.
- Added option "Pano blackout latitude" to the panoramic camera node, which defines the minimum latitude (in spherical camera coordinates) at which the rendering is "blacked out", when stereo rendering is enabled. This is to avoid eye strain, when people try to look up or down at the poles.
- Minor fixes and improvements.
Installation:
DOWNLOAD
