Page 1 of 2
Animation trouble (SOLVED!)
Posted: Wed Apr 29, 2015 2:07 pm
by martincarlson
I'm trying to render an 400 frames animation in Picture Viewer. It renders frame 0, then it stops.
Version 2,22. Cinema R16. Windows 7.
Frame range is set to All Frames. Tried Manual also. Same result.
Save files is checked.
Method: Resend only updated...
Re: Animation trouble
Posted: Wed Apr 29, 2015 7:36 pm
by ChrisVis
Hi martincarlson,
anymore infos on the scene? Screenshots?
Scenefile?
But as I am on R15 I think I would not be able to open it to try it here...
Hope I can help out somehow, rendered thousands of animation frames the last month.
Cya,
ChrisVis
Posted: Wed Apr 29, 2015 8:15 pm
by martincarlson
I don't get it.
This is my settings:
It renders the first frame. Tried both max samples and a time limit. First frame = ok. Then it just stops.
Here is when the first frame is finished. The whole thing stops.
I've tried Resend whole scene, and the other alternative. Same thing happens.
Posted: Wed Apr 29, 2015 8:20 pm
by aoktar
make a clean scene and copy all content. try again
Posted: Wed Apr 29, 2015 8:32 pm
by martincarlson
Ok. Will try.
Posted: Thu Apr 30, 2015 6:54 am
by moebius
Try to render in Render-Manager.
Posted: Thu Apr 30, 2015 8:49 am
by martincarlson
aoktar wrote:make a clean scene and copy all content. try again
Copied it. Same result. Renders one frame. Then stops.
This is with new 2.23.1.
by martincarlson
moebius wrote:Try to render in Render-Manager.
What is render manager?
Posted: Thu Apr 30, 2015 9:14 am
by moebius
Look inside C4D for "add to Render-Manager". Menu > Rendering > Render-Manager...?
I'm sure it's the same name in my German than English
Posted: Thu Apr 30, 2015 9:21 am
by martincarlson
moebius wrote:Look inside C4D for "add to Render-Manager". Menu > Rendering > Render-Manager...?
Ok, Render Queue I guess it's called in english. Same trouble. One frame - then stops.
