HELP ! ... Problem with render setup (texture)
Posted: Mon Apr 20, 2015 11:28 am
We have technical problems with the set up. We kindly ask you for your help.
We attached the screenshots which help you figured out, whats the problem.
1) Comparison of V-RAY and octane Renders.
2) Preset of the all settings.
We have a problem to reach the rendering as it is in reference (V-RAY). WE have problem with mixing the bump, normal map and displace. The quality obtained from the Octane is not as sharp and accurate as it is in V-ray. We hope you will figured out what is missing or whats wrong in the preset . We just started use this program.
Thank you !!
Thank you !!
