IES Lights - Bug ?
Posted: Wed Apr 08, 2015 1:24 pm
by RobSteady
Really strange working with IES lights, see screenshot.
All samples are on 1.
Re: IES Lights - Bug ?
Posted: Wed Apr 08, 2015 1:35 pm
by RobSteady
How to use IES Textures?
I have diffuse material with black body emission applied to a sphere (with normals facing out).
Nothing happens.
Posted: Wed Apr 08, 2015 2:12 pm
by Olitech
Rob,
distribution>IES Texture>Projection>Spherical>positionType>Normal space
But for what you are doing, you don't need IES. Just a square bulb with the emitter texure. Maybe crank up the distribution value to 2 and you're done.
IES is good for simulating pot lights or point lights.
best,
O
Posted: Wed Apr 08, 2015 2:13 pm
by sadece
if i'm not wrong! in here C4D we can not use ies file in material but lights. Maybe same with 3Ds Max?
This is how i use ies..
Posted: Wed Apr 08, 2015 2:21 pm
by RobSteady
Thanks for the quick feedback.
Oli, I only need IES lights on the underside of the kitchen cabinets. The lamp over the table has a light material.
The strange thing is that as soon I switch the IES lights on every other light in the scene gets super dark.
Posted: Wed Apr 08, 2015 2:24 pm
by Olitech
RobSteady wrote:Thanks for the quick feedback.
Oli, I only need IES lights on the underside of the kitchen cabinets. The lamp over the table has only a light material.
Ah, ok. Yeah that's weird.
You sure you just don't need to let it converge with more samples? Just thinking out loud here. We usually need to let it go above 1024 samples to see what the light is doing...
Throwing it out there.
best,
O
Posted: Thu Apr 09, 2015 8:12 am
by gabrielefx
check samples on both emitters, set to 1 then increase it when necessary
use ies emitters and not textures, set them to movable proxy.
Posted: Fri Apr 10, 2015 8:27 am
by RobSteady
Thanks guys.
