Mix Textures Issues
Posted: Wed Apr 08, 2015 10:13 am
by JavierVerdugo
there is limitations with mix textures:
-when you copy an object with a mix texture and you paste in other scene, you copy all materials but the child materials of the mix textures are not copied.
-when you use the function "remove unused materials" cinema 4d remove the child materials of the mix texture.
I hope this could be improved in future versions.
Regards.
Re: Mix Textures Issues
Posted: Wed Apr 08, 2015 11:43 am
by aoktar
- I think you are meaning mix materials. It's not supported this kind of linkage. Put all materials to a null object and copy/paste to other scene.
- Can't you see alternative command in Live Viewer? See "Materials" menu.
Posted: Fri Apr 10, 2015 4:25 pm
by JavierVerdugo
Aoktar many thanks for the tip.
Very cool to add all the materials to a null, perfect solution.
Also the remove unused materials on live viewer, didn't know about! Thanks for sharing this.
