mask and alpha map
Posted: Mon Apr 06, 2015 2:40 pm
by Scottiefeng
Hi guys,
I have got the mask map as below that I want to apply to a knife. I try to make the black part transparent so that it would not block the steel texture.
Any idea how? thanks
Re: mask and alpha map
Posted: Mon Apr 06, 2015 3:02 pm
by linvanchene
Scottiefeng wrote:Hi guys,
You can combine any two image and color nodes with the
"Mix Texture" node.
- In the amount input pin you either plug an RGBA image with an alpha layer or a bw grayscale mask image.
- Mix Texture - OR standalone
Example:
2d plane primitive with
- Tiger.png with an alpha layer.
- Blue RGB color node
Note:
The "Mix Texture" node is not the same as the "Mix Material" node.
Posted: Tue Apr 07, 2015 1:19 pm
by Scottiefeng
linvanchene wrote:Scottiefeng wrote:Hi guys,
"Mix Texture" node.
Example:
Note:
Works! Thanks mate.
