Page 1 of 3
				OctaneRender for SketchUp 2.22.1 - 0.14.159 (obsolete)
				Posted: Thu Apr 02, 2015 7:50 pm
				by fuzzybro
				Hi all,
Here's OctaneRender plugin for SketchUp 2015 matching
Standalone 2.22.1.
Starting from this build older versions of SketchUp are no longer supported.
Download commercial versions
OctaneRender for Sketchup 2015 x64
OctaneRender for Sketchup 2015 x86
Previous build
OctaneRender for SketchUp 2.13 - 0.13.87
Changelog
- Added major features of Octane 2.22.1 (improved kernel, camera and other controls)
- Stability improvements
- Replaced network configuration UI with a windows from Octane Standalone
- Added "reset" buttons to kernel and camera setters in UI
- Added separate DayLight controls to texture and color environment setters when "use sun" is selected
- Attempt to fix: Materials window stays blank randomly
- Pages (a.k.a Scenes) are being exported to .ocs/.orbx as RenderTarget nodes
Enjoy!
Fuzzy
				Re: OctaneRender for SketchUp 2.22.1 - 0.14.159
				Posted: Thu Apr 02, 2015 9:21 pm
				by Seekerfinder
				Thanks Fuzzy!  Can't wait to give it a go.
Seeker
				Posted: Fri Apr 03, 2015 1:55 am
				by rfox
				This is not an April Fool, right? yeah...finally this is new update!!! Thanks Fuzzy
I'll try this out now.
				Posted: Fri Apr 03, 2015 2:34 am
				by resmas
Hello Fuzzy. BIG Thanks for the update.
Allready downloaded...will beggin testing, and report later.
cheers
resmas
				Posted: Fri Apr 03, 2015 4:13 am
				by rfox
				I found out materials window stays blank so often.
				Posted: Fri Apr 03, 2015 6:46 am
				by smicha
				Bro, first of all thank you for your hard work.
When 'show graph' is turned on SU hangs and crashes.
Bro,
I thought we'll have exactly same user interface as in the standalone for materials, viewport, nodes... but this terrible viewport with input data panel is still there.
Any plans to replace the SU viewport with standalone like one? If so, when?
				Posted: Fri Apr 03, 2015 6:51 am
				by smicha
				When I close and reopen the viewport it remains blank.
				Posted: Fri Apr 03, 2015 7:32 am
				by smicha
				Strange things happen - when the 'Show graph' is on the SU hangs, but when I close it (the graph) SU goes back to life.
I also noticed that there are no nodes visible when the viewport is not open - shall it work like this? (I don't think so).
Bro,
My wish (big one
) - just get rid of current viewport and move it to the 'show graph' option, where it would have all its functionality of the standalone. And replace the 'show graph' option with 'Octane Render'. SU shall work only as geometry source, nothing else. Literally nothing else.
I am really happy to see 'show graph' - I wish it wouldn't cause SU to hang. If you have any recommendations of what can be a reason please help.
Good job Bro!
				Posted: Fri Apr 03, 2015 3:43 pm
				by resmas
				Hello again.
Fuzzy we can see that a lot has changed, thank you so much for adding the new render options from 2.22.
But after a few hours many strange things happen.
All that smicha allready pointed happened to me too.
In a new file only with the default 2d man in center if we open the octane viewport, and then close it...after a few moments if we open again,...it stays blank. Only restaring SU solves the problem.
In the "Imager" tab is missing the "highlight compression" option.
Proxies dont have the option to replace component geometry. (I think you said before...that it will be off for now)
My question is how should we use the node graph?
I had some sucess changing some materials, but many times SU crashes if i change many things.
It seems that SU and Octane lose connection...and the crash.
A "small" request....can it be possible to highlight in the nodegraph the geometry we Selected in SU.
Thanks mate.
Resmas
				Posted: Fri Apr 03, 2015 4:48 pm
				by fuzzybro
				You should not use node graph just yet. I just forgot to remove the button because it's not ready yet
