OctaneRender™ for Blender 2.21.1 - 7.10 Linux [OBSOLETE]
Posted: Wed Mar 18, 2015 5:03 am
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v7.10 Linux (96.3MB autoinstaller file)
- Implemented LiveDB support for the new type of gradient texture.
Installation:
# OctaneServer &DOWNLOAD
