Network Rendering 'invalid version'
Posted: Fri Mar 13, 2015 8:55 pm
by BfPuVAK
Hi Paul,
I'm trying to render in Archicad (on master of course) with a network slave (Win 8.1 Pro 64bit & GeForce GTX 560 3072MB), but:
Master and slave have both the identical 2.17 64bit standalone installed.
When I run the standalone on the master, network rendering works without problems!
Might there be a problem with the plugin (2.21.1.40 (64 bit))?
Or do you have another idea?
Thaks in advance & greetings,
Artur
Re: Network Rendering 'invalid version'
Posted: Sun Mar 15, 2015 11:56 am
by rappet
Have you tried as test to render master with slave in standalone ono master instead of from Archicad plugin?
Posted: Sun Mar 15, 2015 4:32 pm
by BfPuVAK
Hi Rappet,
yes, when running standalone on master the slave works without problems (results in ca. 130% faster rendering than only on master).
Only from the AC-plugin it doesn't want to work.
Firewall doesn't have an influence on that, should I try different ports perhaps?
Greetings,
Artur
Posted: Sun Mar 15, 2015 4:42 pm
by rappet
BfPuVAK wrote:Hi Rappet,
Greetings,
Artur
Seems you are running plugin 2.21 and standalone 2.17.. They must be the same to run networkrendering.
You need to install network daemon 2.21 instead of 2.17
Posted: Sun Mar 15, 2015 4:48 pm
by BfPuVAK
Really? AFAIK the standalones have to be identical...
But OK - I'll try that. Thanks for the tip, Rappet
It works
1000 Thanks!
Artur
Posted: Sun Mar 15, 2015 5:35 pm
by rappet
BfPuVAK wrote:Really? AFAIK the standalones have to be identical...
It works
1000 Thanks!
Artur
Great!
