creating an 'random' floor
Posted: Fri Mar 13, 2015 11:52 am
by Jorgensen
hi
i wonder if it's possible to create a floor that consist of e.g. tiles, and they all get random textures applied?
i have created a floor using floorgenerator by cg-source (https://cg-source.com/floorgenerator.php), and tried to add random material ids by using his "Unique Material ID" script, but then i get lost.
i would like to use the "MultiTexture Map" plugin, by the same author, but i can't figure out how to start the plugin, and in the description is octane not supported.
does anyone know how to create more 'random' look floors?
Re: creating an 'random' floor
Posted: Sun Mar 15, 2015 2:03 pm
by acc24ex
just remembered only recently I found out the materialbyelement default 3ds max modifier :) - in max 2015
- add the modifier, it will define random matID and create a multi/sub with different textures..
- didn't try it yet for floors, also looking for quick solutions since all the scripts and plugins look very messy - this seems doable..
http://knowledge.autodesk.com/support/3 ... D-htm.html
- last time I did a good wooden floor, I took a hand scanner scanned the wooden tiles, and cut and pasted all inside photoshop :), looked pretty great, huge map though.. the oldschool way
Posted: Sun Mar 15, 2015 3:07 pm
by Jorgensen
hi acc24ex
i just found out that the floor generator script automatic creates different material ids - so after creating a floor you can add a multi/sub material and it's all fine :-)
Posted: Tue Mar 17, 2015 8:34 pm
by Jorgensen
hi acc24ex
thanks for your tips - it works just fine :-)
thanks
