HDRi Light Flicker & General Noise
Posted: Tue Mar 03, 2015 1:32 am
Alright, I'd really hoped to not add another post to the "Please help, grain everywhere and I'm a noob" list, but...
I have windows that the HDRi light is coming in through. That light is changing a lot from frame to frame (no good, since this is an animation):
Current Settings:
You'll instantly notice the 500 samples - this was lower because I was going to double the resolution and downscale to lower grain.
Result:
This was rendered at 2k, then resized to 1080p for noise reduction (it's obviously even smaller here).
Now this probably wouldn't even be that bad (I get closer to the glass, and there is glass on that table that I get close to in the next camera cut as well)...
But the next frame, the lighting completely shifts. It's inconsistent, even with Coherent Ratio turned up to .45 - when played with the other frames, it's very obvious that the lighting is changing, and it's as if there are fireworks or a turbulent noise light outside causing the light.
Does anyone have suggestions? I've been going through the forums, but it can be hard to pin down something like this.
Thank you!
Current Settings:
Result:
Thank you!
