Rendering Float in C4D Plugin?
Posted: Wed Feb 25, 2015 6:50 pm
by Zee
When I set my rendererer to Octane, set my Save>Depth to 32 bit and set Octane Renderer>Render Buffer Type to Float, I don't see any results. How can I render image to 32 bit in Octane C4D ?
Re: Rendering Float in C4D Plugin?
Posted: Wed Feb 25, 2015 7:21 pm
by aoktar
where don't you see? It can work with 16/32 bit images.
Posted: Wed Feb 25, 2015 11:10 pm
by Zee
When I do a render it's black but live viewer works.
Posted: Thu Feb 26, 2015 12:04 am
by aoktar
i can't estimate what are you doing exactly. More info?
Posted: Thu Feb 26, 2015 12:09 am
by Zee
When I select "octane renderer" as the renderer (from render settings) I don't see it being rendered to the picture viewer when float is picket at octane's settings. If it's set to 8 bit, render works perfectly. When it's float, it renders out black when render button is pressed but it renders fine in live viewer only.
I hope its more clear - if not I can record a video
Posted: Thu Feb 26, 2015 12:22 am
by aoktar
it's not a expected behaviour. Can't remember that was limited or not in demo. But working well in normal versions.
Posted: Thu Feb 26, 2015 3:08 am
by Zee
hmm. i'm having a lot of "what if it doensn't work" sort of questions. I'm generally a bug attractor so yeah
