Motion Blur with instances
Posted: Tue Feb 17, 2015 4:58 pm
by MrFurious
Having a problem getting native motion blur to work with instances. Works with clones but not instances, anyone know how to make this work?
Re: Motion Blur with instances
Posted: Tue Feb 17, 2015 5:07 pm
by juanjgon
MrFurious wrote:Having a problem getting native motion blur to work with instances. Works with clones but not instances, anyone know how to make this work?
It works, but only in F9/F10 final rendering. The IPR doesn't support instancing MB due to architecture problem in the Layout.
Posted: Tue Feb 17, 2015 5:14 pm
by MrFurious
Thanks Juanjo- I'm certain I tried and didn't work in f9 either.. will check again
Posted: Tue Feb 17, 2015 5:18 pm
by MrFurious
Here's a test scene. The first bicycle is the base mesh, the next is a clone, the the last is an instance. The instanced bicycle won't motion blur.
Motion Blur with Instances.zip
(1.13 MiB) Downloaded 253 times
Posted: Tue Feb 17, 2015 5:46 pm
by juanjgon
I think that the problem is that you are instancing an object that already have it's own movement. If you instance an static bicycle you get the right motion blur in the instances. Octane inherit the object motion blur from the object to be instanced and we get some kind of "double motion blur" that doesn't render at all in Octane.
Try to instance an static bicycle and let me know if it works.
Posted: Tue Feb 17, 2015 6:38 pm
by MrFurious
Worked like a charm thanks Juanjo. The workflow I've adopted is to have my static meshes (those I wish to clone/instance) off screen and that gives me freedom to animate the clones and instances.
cheers
