OctaneRender® for Maya® 2.21.1 - 6.4 OSX [OBSOLETE]
Posted: Tue Feb 17, 2015 4:26 am
by JimStar
The OSX version of OctaneRender™ for Maya® plugin, 64-bit.
Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on OSX operating system (including and above 10.8).
Notes regarding features/functionality
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®.
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine
HOW TO PURCHASE LICENSES
Go to our online shop here: http://render.otoy.com/shop/
If you do not own an OctaneRender™ Standalone Edition License yet:
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
If you already own one or more OctaneRender™ Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses, just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
Just like OctaneRender™ Standalone, the Maya® plugin product also needs an additional OctaneLive license and be activated on a machine.
This has to be done in the plugin interface panel in Maya, and is covered in the included PDF manual.
It can only be done after an OctaneRender™ Standalone license is already activated on the machine in question.
THIS IS THE QUICK-FIX VERSION
CHANGES AND FIXES SINCE LAST RELEASE:
  • Fixed value limits in Octane transform nodes.
CHANGES OF PREVIOUS VERSION
  • Added "out of core" settings to Octane globals.
  • Fixed the hair material UI bug.
  • Fixed the db dialog crash bug (happened if you pressed the "open" button the second time when the dialog was already opened).
  • Fixed the LiveDB crash when loading asset containing scattering medium.
  • Minor fixes...
Installation:
- Just run autoinstaller file.
DOWNLOAD
OctaneRender for Maya - v6.4 OSX (18.2MB autoinstaller file)
Standalone: http://render.otoy.com/forum/viewtopic.php?f=33&t=44704
Yours,
The OctaneRender™ Team.
Re: OctaneRender® for Maya® 2.21.1 - 6.4 OSX [TEST]
Posted: Sun Mar 08, 2015 3:21 pm
by p3taoctane
Jimstar
This version is solid. I am unable to do a batch render though. Are you able to mate?
// Result: Saving temporary file: /Users/peta/Documents/maya/projects/default/scenes/15_03_AllPhyto_Blobs_MB__926.mb //
// Result: Rendering with OctaneRender®... //
The batch renderer launches but it just hangs. The GPU does not kick in.
Peter
Posted: Mon Mar 16, 2015 6:46 pm
by p3taoctane
Any word on this Batch Renderign in OSX JimStar?
Also...
I am able to do displacement mapping on shaders ...but as soon as I plug them into a Mix material they no longer show. can you repeat that on your end?
Peter
Re: OctaneRender® for Maya® 2.21.1 - 6.4 OSX [OBSOLETE]
Posted: Tue Apr 07, 2015 2:48 am
by JimStar
Next version HERE.
