Material pick up
Posted: Mon Feb 16, 2015 10:37 am
by Scottiefeng
Hi Paul,
I really like to use the plugin more as it is quite intuitive.
But quite a few times, I could not pick up the material in viewport.
Any clues?
I was about to finish my first ever octane render in one week's time. Will upload for comments.
Re: Material pick up
Posted: Mon Feb 16, 2015 10:47 am
by face_off
Hi Scottie
From memory, the only situations I can thing of where the material picker does not work is if you have selected an AC Object which is a proxy host - in which case I think you can only material pick materials of the selected proxy, AND if you have NOT selected a proxy host, you cannot pick materials from a proxy.
Does that explain the issues you are having?
Posted: Tue Feb 17, 2015 1:29 am
by Scottiefeng
face_off wrote:Hi Scottie
Thanks Paul,
It seems it happens quite and not related to whether I picked up proxy host or not. I have this problem ever since I started using plugin.
Is ther any chance for a 5 mins remote help?
Posted: Tue Feb 17, 2015 2:51 am
by face_off
Yes - I'm on Skype now - pls me a call when convenient.
Posted: Thu Feb 19, 2015 11:20 pm
by face_off
Answering here for all to see.....
Scottie - thank you for sending the scene where you could not material pick.
The problem is caused by what appears to be a bug in the ArchiCAD API. It is truncating material names for geometry when the scene is being loaded into Octane. For example, the material "FINISH | PLASTER | INTERNAL (WALLS+CEILINGS)" is truncated to "FINISH | PLASTER | INTERNAL (WA". So it looks like there is a 30 character Surface Name limit internal to some of the ArchiCAD geometry functions.
For for the wall that you could not material pick - shorten the Surface names to 30 characters or less and it will resolve the issue.
I checked with AC18, and it contains the same limitation, however the problem is caught when loading the scene (with a "No Octane material found..." error). I will amend this error to detect if the material name is 30 chars, and if so to suggest shortening the name.
Posted: Fri Feb 20, 2015 3:47 am
by Scottiefeng
Thanks Paul,
I will shorten the name then.
