Blender plugin not rendering with glass or water material
Posted: Wed Feb 11, 2015 12:15 am
I’m having a lot of problems rendering a blender fluid sim scene when I apply the glass and or water textures. I was able to render the water at one point but now neither material works. However, If I export the scene as an Alembic file and open it in Octane Stand Alone using the exact same water and glass material it render fine.
Please help me in determining what this is occurring. I can send sample files if necessary. Meanwhile, below are my console error messages:
Octane: WARNING: only node-textures are supported: texture "Tex"
Octane: ERROR loading mesh. Server response:
Can't connect node '0x106d65318' (NT_MED_ABSORPTION, 0x7fdcc24436e0) to static pin 'dispersion_coefficient_B' (P_DISPERSION_COEFFICIENT_B, type PT_FLOAT) of node 'ClearGlass' (NT_MAT_SPECULAR, 0x7fdcc24434a0)
Can't connect node '0x11a01ef38' (NT_MED_ABSORPTION, 0x7fdcc2530550) to static pin 'dispersion_coefficient_B' (P_DISPERSION_COEFFICIENT_B, type PT_FLOAT) of node 'ClearGlass' (NT_MAT_SPECULAR, 0x7fdcc2530310)
Can't connect node '0x11a01adf8' (NT_MED_ABSORPTION, 0x7fdcc2643980) to static pin 'dispersion_coefficient_B' (P_DISPERSION_COEFFICIENT_B, type PT_FLOAT) of node 'ClearGlass' (NT_MAT_SPECULAR, 0x7fdcc2643740)
Can't connect node '0x11a03f738' (NT_MED_ABSORPTION, 0x7fdcc4d00d00) to static pin 'dispersion_coefficient_B' (P_DISPERSION_COEFFICIENT_B, type PT_FLOAT) of node 'ClearGlass' (NT_MAT_SPECULAR, 0x7fdcc4d00ac0)
Can't connect node '0x11a040608' (NT_MED_ABSORPTION, 0x7fdcc252dbb0) to static pin 'dispersion_coefficient_B' (P_DISPERSION_COEFFICIENT_B, type PT_FLOAT) of node 'ClearGlass' (NT_MAT_SPECULAR, 0x7fdcc4e03060)
Can't connect node '0x11a03cb08' (NT_MED_ABSORPTION, 0x7fdcc27adb50) to static pin 'dispersion_coefficient_B' (P_DISPERSION_COEFFICIENT_B, type PT_FLOAT) of node 'ClearGlass' (NT_MAT_SPECULAR, 0x7fdcc27ad910)
Can't connect node '0x11b0599c8' (NT_MED_ABSORPTION, 0x7fdcc4f00990) to static pin 'dispersion_coefficient_B' (P_DISPERSION_COEFFICIENT_B, type PT_FLOAT) of node 'ClearGlass' (NT_MAT_SPECULAR, 0x7fdcc4f00870)
Can't connect node '0x11b05d7d8' (NT_MED_ABSORPTION, 0x7fdcc270deb0) to static pin 'dispersion_coefficient_B' (P_DISPERSION_COEFFICIENT_B, type PT_FLOAT) of node 'Water' (NT_MAT_SPECULAR, 0x7fdcc4f00ab0)
