OctaneRender™ for Blender 2.21.1 - 7.1 OSX [OBSOLETE]
Posted: Tue Feb 10, 2015 3:15 am
by JimStar
The OSX version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Merged with Blender 2.73.
  • Switched to 2.21.1 engine.
  • Mute function for Octane nodes is implemented (select node, press "M").
  • Now you can choose in render settings what for HDR you need to render - tonemapped or not.
  • Added Octane render layers. You can set the layer ID in the mesh's Octane properties and enable layers in Octane Layers properties. Global mesh is always on layer "1".
  • Added new passes: "Shadows", "Black shadows", "Colored shadows", "Layer reflections", "Render layer ID", "Render layer mask".
  • Added Octane Noise texture.
  • Added "Affect alpha" attribute to specular material.
  • Removed "Keep environment" attribute from kernels.
  • Removed "Start samples" attribute from passes settings.
  • Fixed the camera rotation bug.
  • Fixed imager presets bug.
  • Minor fixes...
Installation:
- Just run autoinstaller file.
DOWNLOAD
Blender Octane Edition - v7.1 OSX (88.5MB autoinstaller file)
Re: OctaneRender™ for Blender 2.21.1 - 7.1 OSX [OBSOLETE]
Posted: Thu Feb 12, 2015 2:20 am
by JimStar
Next version HERE.
