Mix textures with displacement?
Posted: Tue Jan 27, 2015 8:56 pm
by mikefrisk
Using Mix texture nodes along with displacement. I am seeing no results, any way to accomplish this?
Re: Mix textures with displacement?
Posted: Tue Jan 27, 2015 9:49 pm
by juanjgon
Nope, sorry. Currently displacement only works with the texture image node. All the procedurals and tools nodes are not supported for displacement.
Posted: Tue Jan 27, 2015 10:37 pm
by mikefrisk
Hmm, and there is currently no way to use image sequences/videos as textures?
Posted: Tue Jan 27, 2015 10:47 pm
by juanjgon
Yes, you can use a image sequence with Octane. Load it in the image editor like any other sequence for the native LW engine and use it in the Octane texture image node. To see the animated effect in real time in the IPR window you should enable the "Mat Upd" option.
Posted: Wed Jan 28, 2015 4:29 pm
by mikefrisk
juanjgon wrote:Yes, you can use a image sequence with Octane. Load it in the image editor like any other sequence for the native LW engine and use it in the Octane texture image node. To see the animated effect in real time in the IPR window you should enable the "Mat Upd" option.
Holysmokes! I never thought to material update option for img sequences. Thanks Juan!
Posted: Thu Jan 29, 2015 7:50 pm
by mdharrington
you can use rasterized LW procedurals mixed to your hearts content....as long as they are combined before the rasterizer node.
Which means for displacement, ironically you can combine LW procedurals but not octane.
