OctaneRender™ 2.2 for LightWave™ BETA 1
Posted: Fri Jan 09, 2015 11:17 am
This is the first beta build of the OctaneRender™ 2.2 for LightWave™ plugin. This 2.20.1 release is available for Lightwave 10.1, 11.6 and 2015.1 Windows x32/x64 and OSX x64
This is a beta release, so please consider this more a test or development release which may not be stable enough for a production environment.
Beta release 2.20.1
http://render.otoy.com/customerdownload ... indows.zip
http://render.otoy.com/customerdownload ... .1_OSX.zip
Standalone version for the network rendering nodes 2.20
http://render.otoy.com/rcdownloads/Octa ... _win64.exe
http://render.otoy.com/rcdownloads/Octa ... _macos.dmg
Documentation
http://render.otoy.com/manuals/Lightwave3D/
http://render.otoy.com/manuals/Lightwave3D/?page_id=717
RELEASE 2.20.1
* NEW FEATURES:
- Optimizations in the mesh builder to make it faster and save GPU memory. This version saves up to 60 Mb of GPU RAM per million of triangles.
- New mesh functions to support multiple UV maps. Currently Octane has been enabled to support up to 3 UV maps in each object.
- New option "UV Set" in the Texture Image node to select the UV map that will be used by this texture. Currently the LightWave UV map names are not available for this node, so you only can see 1, 2 or 3 as map names.
- New option "UV Set" in the Infochannel Kernel to select the UV map rendered in the UV channel output.
- New option "UV Set" in the Render Passes node to select the UV map rendered in the UV channel output.
- New "Affect Alpha" feature in the Specular material node. This feature makes specular materials transparent in the alpha channel.
- The option "keep environment" got removed from the render kernel nodes. This option never really made sense, since blurry effects like DOF don't work with it. With the modified environment render pass you can now compose something between the environment and the scene.
- The environment render pass is now an info pass and will contain the environment over the whole image.
- New "Environment Max Samples" option in the info pass node
- Support of the LightWave 2015 overscan feature.
- Support of the Octane Render Layers. New core code to manage the render layers at objects level in the scene, store the layers setup in the scene file and so on.
- New "Render Layers" command to open the render layers configuration panel. This command has been added to the main Octane menu branch.
- New feature in the IPR window to set the current render layer. Minor changes in the IPR buttons layout to add the new render layers menu.
- New "Layers" options tab in the render target root node panel with the layers rendering options for the F9/F10 rendering.
- Added the render layers code to the main core rendering loop. The layers are rendered for each frame without reload or update the scene to be as fast as possible.
- Added the layers rendering status to the rendering preview window.
- Support of rendering layers file name postfix while rendering sequences using the LightWave native save file functions.
- Support of rendering layers file name postfix while rendering using the Octane passes node.
- Added five new render passes to work with the render layers: Layers black shadows, layers colored shadows, layers reflections, layers ID and layers mask.
* BUGS FIXED:
- The UVMAP node can crash the Layout if used in objects with more than one UV map. Fixed.
- The Octane CUDA error messages are now available in the LWSN console window.
- The "Scale" parameter in the medium nodes is not a distance parameter, it is a multiplier parameter. Now it is a standard floating point parameter.
- Polygon artifacts in the spline hair guides obejects. Fixed, now the plugin filters the spline polygons to don't render them.
- Crash in a polygonal hair scene. Fixed.
Beta release 2.20.1
Documentation
RELEASE 2.20.1
* NEW FEATURES:
* BUGS FIXED:
