problem with many objects
Posted: Tue Jan 06, 2015 1:46 pm
by Maciej
hello everyone, I need help,
problem whit render, when I have more object in the scene.
for example, with one tree (octane proxy) is OK.
but when I have more trees, scene it loads endlessly.
what I do wrong?
PC
RAM memory: 64GB
GPU: 3 x nvidia geforce gtx 780ti
Re: problem with many objects
Posted: Tue Jan 06, 2015 4:08 pm
by akira
Hi, there are two things you need to look at:
1. make sure you choose "Instance" when duplicating these proxy trees instead of "Copy".
2. select all trees and right-click -> Octane properties -> Turn on "movable proxy" flag.
Posted: Tue Jan 06, 2015 6:59 pm
by Maciej
Thanks akira!
when is one type of Tree is OK
but the problem coming when is more types of trees
Posted: Wed Jan 07, 2015 1:01 am
by coilbook
i have this problem if i accidentally set movable proxy to dummies or some other helpers especially linked ones. I usually uncheck movable proxy for itoo forest, if you use one.
Try to select all objects in your scene and go to their octane properties and uncheck movable proxy from all of them and see if it works like that.
Posted: Wed Jan 07, 2015 3:52 am
by akira
the available memory of your GPU is too low, only 0.77GB left, are there other applications running(photoshop or ae or premiere or games)?
Posted: Sat Jan 10, 2015 9:48 am
by Maciej
coilbook wrote:Try to select all objects in your scene and go to their octane properties and uncheck movable proxy from all of them and see if it works like that.
coilbook - I do as you suggest, but nothing has changed
I do not know what can i do in this case
whit itoo forest work great. but I have not tried with many types of trees.
Posted: Sat Jan 10, 2015 10:06 am
by Maciej
akira wrote:the available memory of your GPU is too low, only 0.77GB left, are there other applications running(photoshop or ae or premiere or games)?
I have no other programs running, in this case ( 5 types of trees ) Octane use only 0.77 GB memory.
I have always so little memory of my GPU (max 2,0 GB). I thought it was normal
vor exemple:
https://www.youtube.com/watch?v=uHcmX-HL1Mo
this Gay also has a 3x GTX 780 and has ~1.8GB memory.
Posted: Sat Jan 10, 2015 8:57 pm
by akira
have you disabled SLI in nvidia control panel?
http://render.otoy.com/forum/viewtopic. ... LI#p217584
If it still renders slow after disabling SLI, i think it's time to PM master Karba for help.
Posted: Sat Jan 10, 2015 10:11 pm
by coilbook
Maciej wrote:coilbook wrote:Try to select all objects in your scene and go to their octane properties and uncheck movable proxy from all of them and see if it works like that.
i noticed if i have like 5 trees and i instance them it will render very slow. But if I have these 5 trees and use itoo forest with 200000 instance copies of them it will render very fast. Not sure why
Same if I convert itoo forest cloud point trees to actual viewport mesh it will render like 20 times slower
Posted: Sun Jan 11, 2015 11:14 am
by Maciej
thanks! This was the problem. now everything works great!
