Test composite
Posted: Thu Nov 18, 2010 3:47 pm
by MaTtY631990
Just a test composite of an elephant I made in MAX and a background with little colour correction in PS.
Re: Test composite
Posted: Thu Nov 18, 2010 8:35 pm
by tehfailsafe
How did you get the shadow?
Re: Test composite
Posted: Thu Nov 18, 2010 8:49 pm
by face
That should be a Max shadow because you see the underlying mesh.
Thats because the Octane render result don“t match other 3d-apps render results to 100%.
face
Re: Test composite
Posted: Fri Nov 19, 2010 11:57 am
by MaTtY631990
tehfailsafe wrote:How did you get the shadow?
face is right, the shadow pass was rendered from 3ds max but it can work. you set your to align in 3ds max
with a plane to catch shadows. A pure white diffuse material for the plane. Set your sunlight in max via plugin and switch on raytraced shadows and adjust to your liking.
All I did was render a single picture in octane, render an alpha for the elephant and shadow pass in max. make sure to right click on your model and in object properties, turn off recieve shadows.
I included the render passes to show you result.
